in the flat i rent at mo | on ElectriciansForums
Discuss in the flat i rent at mo in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
the cable feeding my cu looks like it is all in one, with one 10mm line , 6 x 15mm neutral and 4 x 4mm cpc,
now it seems like it aint a complete cable but i bet you it would of been awkward to fill the sheath like this...
anything to say knowledgable souls..
if i can find camera lead il upload in a min
split-con???
[ElectriciansForums.net] in the flat i rent at mo
well theres no rcd on the supply side of this , mind you probably been in 20 years if not olonger
i was thinking as it over 3m it would require rcd protection... but suppose installed to differnt edition
Reply to in the flat i rent at mo in the Australia area at ElectriciansForums.net
