Inaccessible clamp on main bonding. Compliant? | on ElectriciansForums
Discuss Inaccessible clamp on main bonding. Compliant? in the UK Electrical Forum area at ElectriciansForums.net
DNS1
I'm upgrading some main bonding prior to a board change, but got a quick question.
The incoming water supply is a metal pipe below the wooden floor in the living room, but the stop cock is in an inspection pit outside.
As I understand, the bonding has to be connected as soon as possible inside the property, but that means the bonding would be run to a clamp which would not be accessible without lifting the floor.
Current bonding is to a previous edition (15th I think) and is just connected to a random internal water pipe which is quite a way down the system.
What's the best way to proceed with this one?
The Regulations require extraneous-conductive-parts to be bonded.
It doesn't really matter where the connection is made, just as long as it's made.
With services, the requirement is to make the connection as close as reasonably practicable to where the service enters the premises.
This is a precaution against the connection being removed at some time in the future.
How likely is it that at some time in the future, the pipework with the bonding connection will be detached from the rest of the plumbing system?
In older houses in my area of the UK the water always comes into the house just as you come into the front door and that is where the stop tap is located, so there is always a hatch to allow you to get to the stop tap, thats where the bond should take place.
Now if its not accessable then as the other's have said fit it where it first comes out of the floor.
This is not correct......The reason the connection is required to be made at the point of entry,or first accessible position, is because the hazard the bonding is dealing with comes from outside the property,as long as the bond is made at the point of entry the hazard is dealt with and it does not matter what happens to the pipework beyond that point..But
if the connection is made further up the system there is a pssibility of an unbonded ECP between the bond and point of entry if an insulating insert or a poor continuity joint is installed.
If the service is bonded at the point of entry there is no possibility of the service being unbonded regardless of insulating joints/poor continuity joints unless the connection is physically removed.
Reply to Inaccessible clamp on main bonding. Compliant? in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
