Hi everyone,
On a job at the moment and trying to
Work out cable size needed for property supply. Lots going on and struggle to work out potential loads of new build not built yet.
Loads
2 x ring main around 15 sockets
Lighting circuits consisting of around 60 spotlights and outside lighting
Electric heating system been told is 32a.
Induction hob or no amp hob not been specified, will go
Induction for worse case
Kitchen ring and circuit for usual appliances
it is a 4 bed house about to be built but they are not massively clear until walk round with client once build is at first phase.
Going off calculations of what I’ve done so far on rough info I’m estimating a 35mm SWA.
There is a green cabinet at front of driveway and is a TT system l, 60a main fuse, and is going to be about a 50metre run ducted in the ground.
No grief please.
Loads
No grief please.
