Incoming tail retaining clips | on ElectriciansForums
Discuss Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
Skimpy Wan
Does anyone know where you can buy clips for the incoming tails like the DNO use (figure of eight design)? If not, what do you use to hold them back (SWA glads)?
Sent ... using the force!!
I'm due to extend the tails as I need to dropped the CU by 1.5 metres (from above door to 1350 height for elderly couple). Normally I'd use cleats to hold the tails back, but I didn't know if we could buy similar cleats to the DNO as they have 1 fixing for both tails)?
[ElectriciansForums.net] Incoming tail retaining clips
Like the cleats in this picture?
Reply to Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
