Incoming tails 16mm | on ElectriciansForums
Discuss Incoming tails 16mm in the UK Electrical Forum area at ElectriciansForums.net
if it's just an isolator you are fitting, fit a 100A,that is just it's max. current loading, don't matter if you only pull 40A, 60A whatever , as long as it's not more than 100A. if you're talking about a fused isolator, that's different. the fuse should be less than the DNO fuse, to provide discrimination.
Reply to Incoming tails 16mm in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
