Increase current amperage by using darlington transistor | on ElectriciansForums
Discuss Increase current amperage by using darlington transistor in the UK Electrical Forum area at ElectriciansForums.net
Malaysia
I'm using DC adapter 5.8 volt with 580 miliamp to produce 1.5 amp by using a pair of NPN transistor 2N3904 to be build as Darlington circuite.
Is it possible?
Is it possible?
I think you would need to show us your full circuit design. The Darlington pair is literally just two transistors acting as a high gain pair.
i see, I just to booast the amperage but don't care to lower bujt simply used to charged two 1.3 Li-ion battery :)
You could in theory build or buy a buck converter to generate a lower voltage at higher current, but given 580mA at 5.8V (3.3W) available, the max voltage you could get with 1.5A draw would be around 2V,
I may be missing something, but a Li-Ion cell is normally 3.7V, not 1.3V. NiCd or NiMh batteries are 1.2V.
Where does the 1.3 come from? But you can have 1.3Ah Li-Ion cells!
I see, It is Nimh cell with two batteries.
Reply to Increase current amperage by using darlington transistor in the UK Electrical Forum area at ElectriciansForums.net
