Indication Lamps | on ElectriciansForums
Discuss Indication Lamps in the Australia area at ElectriciansForums.net
speedtronic
Can we use a 130V 20mA indication lamp in place of 130V 2W indication lamp? If yes please explain why?
As long as they both fit the same lamp socket then cant see why not. As for an explanation its just like changing your gls 100w lamp at home for a low energy, just as long as the voltage matches and the lamp is suitable for the lampholder and enviroment then it should be ok.
The only snag would be if the light output had to meet some sort of requirement you new lamp needs to achieve this i assume.
As above really but think darkwood might have read it he the wrong way around - your new one is taking slightly more current than the old 2 watt one which was taking 15mA (2W / 130V). So if you are testing to earth the new one gives slightly less leeway in terms of tripping an RCD.
Well spotted didnt bother working out :eek: think i went into automatic with the explanation rather then the calc's. lol
Reply to Indication Lamps in the Australia area at ElectriciansForums.net
I personally have two Integral Evofire Recessed (low-glare) on trial at home outside the UK; just realized they were, however, made of steel. The...
As if my handle doesn’t give the biggest hint. The pod light above the winch is the one I’m referring to. I don’t foresee any issues with using a...
