J
jd321123
Hi, I have recently had the kitchen rewired and want to fit a 7.2kw induction hob. Wire in wall is 6mm t+e to the power outlet backed up by a 32a mcb. the hob will be installed in the worktop directly above a built under double oven. The instillation manual for the hob specifies cable type ho5v2v2 f to connect it to the mains. I cannot find this cable anywhere. The electrician who carried out the rewire says that he would usually use standard 6mm t+e.
I take it that the cable may have to have a higher heat resistance than standard t+e? If thats the case would this cable be suitable that i have found on tlc direct website? Or what would you guys use?
3183tq 3 core butylflex 4mm
Thanks, Jack.
Thanks, Jack.
