Would appreciate your thoughts on this please.
Wylex split load consumer unit with one rccb, new circuit installed for induction hob on non rccb side with 32 amp rcbo.
When the hob is switched on the rccb trips, not the rcbo. The circuit has been tested out and is fine and the neutral for the rcbo is in the correct neutral bar, both rcd and rccb pass on the rcd tester.
Don't know if anyone has come across this before, will change rccb tomorrow just in case it has an intermittent fault but would appreciate any other ideas.
John B
John B
