induction hob wiring? | on ElectriciansForums
Discuss induction hob wiring? in the Australia area at ElectriciansForums.net
E
essexboy
morning all, stopped to have a look at a job last night and the customer has a domestic induction hob to be fitted ( model ind60t ) no wiring diagram or installation details. the hob has a 5 core cable pre-wired
earth
blue
brown
black
grey
never come across this before ,has anyone got any idea of wiring these up?
think you'll find it' can be wired 3 phase. you need to find out the rating ( KW ) to determine your cable/MCB ratings. i assume you would link brown/black/grey for single phase. best check with manufacturer ( indesit? )
That's fairly normal with the induction hobs however usually the brown, black, grey and blue have terminals crimped on the ends so you end up with 2 pairs of connections. Have these connectors been cut off? From memory brown and black were joined and grey and blue were joined but please don't take this as gospel as it was December since i last connected one up. The last one was a 5 ring Bosch hob which sat happily on a 32A supply with a separate oven on it too. Gotta love diversity! :D
earth
blue
brown
black
grey
Call the maunfacturer (or look on their web site) and get a copy of the installation instructions. Anything else is madness
Definitely get a copy of the installation instructions, and if you do speak to the manufacturer treat any verbal advice on the phone with caution as the chances are you'll be speaking to someone who hasn't got a clue!
i've come acroos similar. in the ones i've seen, you have terminals marked L1,L2,L3 & N. this is for 3 phase operation. but as said before by me and others, makers instructions are bestr way forward. without seeing it, we are only able to guess.
Reply to induction hob wiring? in the Australia area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
