Induction Hob | on ElectriciansForums
Discuss Induction Hob in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
UK
I am PAT testing an induction hob. It passes the Earth test, but then fails on the Insulation Test. Item is about 3 years old, no damage to unit or cables both inside and outside....Any thoughts
The IR must be low anyhow . Not familiar with pat testing but what are the IR readings
Earth test and insulation test won't necessarily both pass together. Just follow procedure for the test anyhow
Someone probably be along knows exactly what's up 😁 no doubt
Reply to Induction Hob in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
