B
bal
Hi,
Just a quick general query.
I'm a technician overseeing the installation of an industrial fan in the apex of a factory about 25ft off the ground.
A fan controller is located on a wall in an enlcosed area - as the fan itself is high up in the apex approx. 25ft high I have installed an isolation switch next to the controller - this isolates power to the controller and by default the fan itself.
The distribution panel supplying power to the panel is located 10 feet away from the fan controller.
Is the isolation switch location ok or should it be near the fan 25ft up?? - I think in residential installations an isolation switch needs to be near the fan itself - does this apply in an industrial environment?? given the height of the fan above the controller.
regards
regards
