industrial heaters | on ElectriciansForums
Discuss industrial heaters in the Talk Electrician area at ElectriciansForums.net
Evening All,
can anyone advise of the best means of electrically heating an a large area 50x30ft, containing electrical control panels , the aim to prevent any moisture ingressing the electrical equipment( motor pumps etc.
Are you thinking about heating the entire area? You could end up with a hole in the ozone layer named after you :) Why not just use a small DIN mounted heater in each panel.
Problem with gas is that H2O is produced as a by product of combustion so it's likely to increase the relative humidity as well as warm up the space. As soon as the temperature drops again to ambient there will be condensation everywhere.
Of course. i was thinking of the high bay heaters used in garages etc..
I've not come across the heaters you mentioned, I will have a look now.
TBH it's why I posted my second opinion on the problem.
I’ve got to agree with Marvo, install local panel heaters. But be sure to ventilate the panels otherwise the panels will be wet through.
I don't think i've seen any switchboards, MDB's or other electrical panels of any consequence not to be spec'd and provided with panel heaters. All run through a thermostat to ensure the enclosure doesn't drop below a preset temperature!! Can't ever remember having to retrofit a panel heating system before, but then i guess i wouldn't expect to, on the sort of projects i work on...
For that size, if you have gas, fit a warm air heater that has flue to outside, you have to use a flue on those anyway, then all the water vapour goes outside. Plugs and Sparks Ltd does a good line in these heaters if anyone is interested.. :)
Reply to industrial heaters in the Talk Electrician area at ElectriciansForums.net
Thank you for the suggestion!
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
