Look closely at that roof and you'll see that they have a support / purlin structure every 1.2m under the roof.
(Panels are 800 wide, 15 panels = 12m, look closely at the transparet ones and yiu can see a mid support, plus there will be a support at each panel lap, 5 panels = 10 supports + eaves, covering 12 m = 1.2m)
As an engineer, unless it has a structural roof covering it isn't going to support it, they will need to put some intermediate supports in, typically aluminium rails need to be anchored for two reasons.
Load - bending, deflection
Uplift from wind, it needs to be securley anchored to the substructure. You could easily have mountings just ripped out from the substructure.
As such you'll need something custom if you want to span more than 1.2 - 1.5 meters.
So your solution would have to be a custom substructure support system of some kind, and then you can put any of the popular flat roof systems over the top. - Schletter has some great products for industrial roofs - go take a look at their site.
Schletter GmbH | Home
Once again - you NEED to get a Structural Engineer to look at it , and that should be your advice. -
"There are loads of mounting systems that can do it, however before we can say wether it can or can't be done, you'll need to get a structural engineer to check it out"
