Industrial use of flex cable | on ElectriciansForums
Discuss Industrial use of flex cable in the Electrician Talk | All Countries area at ElectriciansForums.net
B
bal
Hi,
General cable query.
Is it ok to use normal flex cable where it is installed above head height ie not easily accessible or should we be using something with more protection ie SY cable??. We are talking low ampage applications (1-5a) in a pretty low haz environment.
regards
What type of environment is it....warehouse, factory etc.
I'm not keen on using boggo flex (unprotected) anywhere except a domestic install.
In conduit for example would be ok or as you suggest SY.
Hi,
regards
i flippin hope so,
Its in a factory - runs from a light control panel up into the apex - its not pinned to the wall but is layed in the steel roof structure.
ive used it for low voltage suff eg 12-24 v
We have a large amount of automated production lines inside restricted caged areas. Its impossible to wire these with SY or armoured, so lots of 3Phase flex is used - low ampage stuff only like conveyors. The cables are placed in trays along the floor but in some areas this isnt possible either - so assuming there is no traffic and restricted personnel only I assume flex can be used more or less anywhere.
Thanks for the info.
Thanks for your input - in our environment (see previous reply) its sometimes not possible to use anything else.
Reply to Industrial use of flex cable in the Electrician Talk | All Countries area at ElectriciansForums.net
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
