industrial welder. any advice | on ElectriciansForums
Discuss industrial welder. any advice in the Commercial Electrical Advice area at ElectriciansForums.net
Davey1988
Hey guys
I want help on this forum about cpc and I heard I won't get any am I right?
Calculate cpc size using the adiabatic equation, exactly the same as any other circuit.
And put your best tin hat on before anyone else answers this, if you aren't on a wind up you are going to be catching some serious flak!
To save future embarrasment I deleted it.
2 phases. No neutral. And cpc
80 amp fuses per phase. Max leakage imo can be no higher than 160amp.
First time in dealing with welders not 100%
No, they use the cpc as a cpc and a neutral as a neutral if one is required. It sounds like the machine you have is designed to operate on two phases of a three phase supply, unless of course it's designed for a two phase supply?
You need a lot more than a little guidance, you clearly don't understand the first thing about the job you are attempting to do.
thinking worst case senario. Do welders use a cpc to act as a neutral. little guidance is all I need and I'm finding it really hard to get it on here.
Some welders have 200amp - 400amp earth clips.....
I think you are getting confused with the terminology,referring to the OUTPUT side of the machine.
The terms and figures only make sense,if this is the case.
Do a bit of research,and all will become apparent...but do not attempt,if unsure,and some other human is to test its' operation...:conehead:
Think along the lines of electrode (live) and work piece (neutral return). The I/P and O/P are two separate entities.
Where I’ve seen things go badly wrong is when the CPC has been used for the return. Do some reading on the subject, as a hint, don’t bother looking in BS7671.
Yep, I recently had a call out because a welder had set the cpc on fire in the DB and it even made the trunking rattle, lol. I repaired the circuit and offered to check the welder to make sure it was wired correctly but they thought it was dangerous so the had ditched it before I got there...
Reply to industrial welder. any advice in the Commercial Electrical Advice area at ElectriciansForums.net
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
T
Industry Accreditation (IA) CSCS Cards Can No Longer Be Renewed - From TTA Industry Accreditation (IA) CSCS Cards Can No Longer Be Renewed - From...
The Tile Association
T
