A
axel132132
Hi,
Im looking at installing power to a GARAGE the garage is around 30meters from the consumer unit and will be drilled through the wall clipped up the wall and across a centenary wire into the garage to a new two way consumer unit in the garage.. Which is going to supply 1 x Double socket and 2 x fluorescents and a 360 sensor.
What size cable and what type of cable will i need and what size breaker for the consumer unit will i need? (It has RCD protection and the new board will also be RCD Protected)
