Info please - help? | on ElectriciansForums
Discuss Info please - help? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
P
philsheriton
need a bit of advice in the middle of an electrical course c&g 2381 pat testing 2377part p Bpec defined scope and the 17th edition aim to go as an independant spark domestic eventually have been told i Need full scope not suse of next move phil
Phil defined scope level B means you can wire in single circuits ONLY
Level C means you can alter existing circuits ONLY
if you want to be a domestic sparks you need to be full scope - unnless you just want to move single sockets in the kitchen for living!!
Are you doing the full 2377??? Both units???
oh, and when you say you are in the 'middle' of the training, have you done the 2381 yet? if not you have a only a few weeks before C&G pull the exam. If you HAVE done it und your 17th is 2382-20 (the update) then thats fine. If not, then shortly you will need to do the 'full' 17th - 2382-10 straight off
Upvote 0
Reply to Info please - help? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
Electrical Courses
