info re old shower isolator | on ElectriciansForums
Discuss info re old shower isolator in the UK Electrical Forum area at ElectriciansForums.net
birighton
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the isolator sw is feed with 6mm and fuse on board is a hager mtn132 /b32. the board has rcd . i would like to add two sockets to my loft . can i add a 4mm radial feed from the 6mm isolator in in to the loft for the 2 sockets i plan to set up a gaming room up there and a heater for colder months from my son . thanks for any help should add i am in the uk :)
Ok, depending on cable route, whether it’s through insulation or not…. But can down rate the mcb to 25 if need be.
the 6mm comes from board understairs then bout 4 foot under landing floorboards the up the side of the airing cupboard wall to the isolator from the isolator to loft is 650mm stright to ceiling no insulation where cable will go in loft then it will run 2 meters in trunking two the two sockets
Reply to info re old shower isolator in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
