Infrared beam help | on ElectriciansForums
Discuss Infrared beam help in the Australia area at ElectriciansForums.net
W
Welshsparky
Hi all
We have a job next week to install an infrared beam across a gate,Which sets of an alarm when broken,Does anybody know the best way to wire this coming from the DB?
The last one i done worked from the gates control box and was low voltage 12 or 24 volt so it could be wired in t&e , but if you are connecting to an alarm it probably worth getting some external alarm cable 3 or 4 pair
is it a stand alone system or connected to the building alarm system,you wont get t&e in them,their 12vdc jobs,just fit a small alarm panel which can be set when ever they need it to be and either connect a sounder or a buzzer/led if its say going in a gatehouse,and id fit the twinbeams over single beams,as external you can get problems with false alarms with single beam ones due to birds.fox's etc
we use these a lot,quality kit
Optex- Outdoor
Reply to Infrared beam help in the Australia area at ElectriciansForums.net
Whatever... I awoke this morning ready for an intersting and relaxed day at work at my local branch of the Men's Shed charity. " jobs pending...
thanks for the reply mate, I am currently working with a qualified electrician gaining experience been like 5 months with him now all domestic.
