I'm looking for confirmation or otherwise, that the following bits of kit will go together to create a temperature controlled heat source for a curing application via a standard 13a plug fitting.
- 2 x 400W ceramic elements in reflectors (1 fitted with Thermocouple)
- PID temp controller, 1 relay output, 100-240V AC
- Solid State Relay, 10A, zero crossing, Triac, 280V max load on heatsink
- all connected with 2.5mm single core control cable
Thanks.
Thanks.
