Inline fan switched from two locations | on ElectriciansForums
Discuss Inline fan switched from two locations in the UK Electrical Forum area at ElectriciansForums.net
S P
Good evening all,
Has anyone ever installed a fan like this before?
The issue I don't know the best way to overcome is that if I wire each bathrooms SL to the fan it will back feed and turn the lights on for both bathrooms.
The best I've come up with is 2x contactors - one SL to each input - then both outputs to SL on fan isolator. L+N from both junctions straight to fan isolator.
Is there a better way of doing this?
I thought it would be a good idea as it is serving two small back to back en-suites, accessible loft space above for the fan. They are much more powerful than the standard wall/ceiling units. Plan was one duct out - Y joint at fan to each room.
The contractors will cost around ÂŁ55 so unless someone knows a better solution it makes more sense to install two fans.. They cost ÂŁ65 each
Thank you
Use double pole switches. One pole for the light in each room and the other pole as the fan on/off.
Cointactors, relays and the like not required!
[ElectriciansForums.net] Inline fan switched from two locations
Simples!
Thanks Taylor, Jack
Both rooms have no natural light.
Do you think this needs to be followed? Quote From IET forum:
You do not have to use a timer fan at all.
The only legal requirement in the Building Regs. is "There shall be adequate means of ventilation provided for people in the building."
Anything noted in the Approved Document for Part F is merely a suggestion. As the Approved Documents themselves point out, "There is no obligation to adopt any particular solution contained within an Approved Document if you prefer to meet the relevant requirement in some other way."
However, even if one were to try and follow the guidelines in the Approved Document for Part F, the section is rather vague. Here's the relevant extract, page 18, table 1.5:
Mechanical intermittent extract
Intermittent extract can be operated manually and/or automatically by a sensor (e.g. humidity sensor, occupancy/usage sensor, detection of moisture/pollutant release). Humidity controls should not be used for sanitary accommodation as odour is the main pollutant.
In kitchens, any automatic control must provide sufficient flow during cooking with fossil fuels (e.g. gas) to avoid the build-up of combustion products.
Any automatic control must provide manual over-ride to allow the occupant to turn the extract on.
For a room with no openable window (i.e. an internal room) the fan should have a 15 minute over-run. In rooms with no natural light, the fans could be controlled by the operation of the main room light switch.
Good evening all,
Thank you
What exactly are you trying to do as your post title mentions switching a fan from 2 positions, now it's 2 fans?
Hi Pete,
Thanks for your time. It's one fan I want to control if practically possible. Ideally with timer over-run operated via SL from either bathroom.
The two fan's mention was me saying is it wiser to scrap this idea if it doesn't have legs...
Hi Pete,
Configure the fan as a two way light and use 2 2way switches to control the fan
Thanks. That would work, so the contactor idea is overkill then?
What you suggest isn't against any regs but Part F suggest:
"For a room with no openable window (i.e. an internal room) the fan should have a 15 minute over-run. In rooms with no natural light, the fans could be controlled by the operation of the main room light switch."
Would you write anything on the cert or not needed as you've complied with building regs: "There shall be adequate means of ventilation provided for people in the building."
FYI both rooms have no natural light
If you wire the fan as a 2 way,it can be switched off by the other user when you happen to want it left on
It would not have capability of a dinky little neon to tell if its off or on
If you wire as suggested with double pole switches,there can be no back feed to the other light because that would need their double pole switch in the on position as well to back feed to the light
The double pole switches can also have their very own dinky neon on the outputs
2 fans , why make a simple job harder
DP switch much easier. However, if you opt for two fans, sharing one extract duct then you'll need to consider the issue of air backfeed from one room into the other.
The last thing you want is Vindaloo poo from one room being pushed back into the other. To solve that you'd need two backdraft flaps in the two fan outlets, and probably a larger outlet duct after the Y piece to cater for when the two fans are going at the same time.
So two fans not so simple a solution.
Reply to Inline fan switched from two locations in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
