Inline fans - ?? | on ElectriciansForums
Guest viewing is limited
Discuss Inline fans - ?? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So I've got a client who has 2 failed inline fans - they are old so they need replacing. Money is tight so the obvious answer is to install the "fan/light" kit and keep the parts I don't need or suggest the high pressure type - OR is there a cheap inline fan only part available. Being dense today so help is appreciated!
I've been using vortice in line fans. They are a lot cheaper than the likes of vent axia and do the job very well. They have all the options of high and low speed and adjustable overrun timer. And they come as the fan motor only the rest is brought as extras so you can keep all your old ducting and vents. They are 4 ducts and we pay about £60.
You can buy an inline fan for £20.00 fella, but I use vortice as mentioned by onions myself and use double insulated duct as well, thats costly, but you can get a cheap inline from CEF or denmans for under 20 notes.
Reply to Inline fans - ?? in the UK Electrical Forum area at ElectriciansForums.net
Thanks very much, also a good tip :)
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
Recommended Sponsor News
Hi everyone,
