Inline potable expansion valves Has anyone fit inline expansion valve on the cold water supply to an unvented cylinder. The normal style were you just tee of after the composite valve can leave a dead leg in the pipework? A local water authority has pulled some. Thanks
Inline potable expansion valves to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
