inline shower fan | on ElectriciansForums
Discuss inline shower fan in the Australia area at ElectriciansForums.net
hi need some advice. Recently fitted a 100mm 20w standard inline shower fan for a very small shower room. the fans stated extraction rate is 90m3 but it appears to have very little suction and the customer is stating that it isnt clearing the room when the shower is in use. Now i have checked the ducting and it appears to be extracting as there are signs of water in the ducting where it attches to the fan. Now is it a case of the fan just not beeing powerfull enough and i need to fit a more powerfull fan ? As i thought 90m3 would be sufficent any ideas please?
to add this is the first inline fan i have fitted so not too sure on how much suction there should be/ or you can feel. All i know is that when the fan is running it wont even hold a smoke paper or piece of tissue to the grill is this normal
thanks stuart. The fan is made by a company called airvent was part of a kit the customer supplied. i did not do the full install just replaced the broken inline fine with a new one too existing ducting and wiring (fusing down to 3amps as required) only thing i can think of is the fan is 5ft away from the inlet grille could this be causing a problem? if so it will have to be rewired so it can be repositioned. But it sounds like the fan is just not powerfull enough or is faulty as i said it wont even suck a smoke paper to the grille.
yeah ive told the customer that a larger fan higher extraction may be required. a mixed flow in line fan ( 180m3/245m3 ) should do it, Do you think the length of ducting from fan to inlet grille is the problem ? thanks stuart for your advice
Just sounds like its not big enough for the job!A decent centrifugal would be better.60 odd quid
Axial fas won't handle much pressure, the mixed flow variety are generally better at handling pressure, they're also quieter and they don't overload the motor if grills become blocked. If it's a very small bathroom (like an en-suite) I would work on at least 20 room changes per hour. Measure the volume of the room and multiply by 20 to get the hourly volume required. Then find a fan that can do that duty. You might also need to fit an air vent in the door if the room is well sealed to allow the fresh air in that's replacing the extracted air.
Reply to inline shower fan in the Australia area at ElectriciansForums.net
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
