Hi all, was wondering if anyone could help me with this. I have had a three phase induction motor rated at 85.8amps full load and voltage is 480volts connected in delta. My question is that when I was first starting up the motor it kept on tripping the main switch due to the inrush currents. The rated inrush current from the manufacture was 755amps so was set to that but was still tripping so I set it a bit higher and still tripped I kept on increasing until it never tripped but it is over the inrush current rating. My question is how high can you set your inrush current dials to? If there is belts connected to this motor at that moment in time will that increase the inrush currents to get the motor started? Also if that motor is pulling something will that increase the inrush currents aswell?
Any replies will be much appreciated?
Thanks trig
Thanks trig
