Inspection,Testing and Certification | on ElectriciansForums
Discuss Inspection,Testing and Certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
wigan
Is there anyone out there who wants to buy a 2391-10 that I got in 1998?
(equivalent to the new 2391-52)
I don't quite understand. Are you selling your qualification???
Guess they need the same date of birth and same name then? they are quite hot on fake qualifications now, when applying for the gold cards the JIB lot have access to the eal and c&g database to check qualifications and some big companies use experian to verify your qualifications against the central government qualification database. for low level jobs you probably wont be found out until asked to do something which is routine for a qualified spark then you will quickly come unstuck and possibly kill yourself or others at worse..
Just having a laugh!
To be honest Im fecking fed up with it.
I does some testing (mainly in ver)
And every time the site eng says (how long will you be?)
Reply to Inspection,Testing and Certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks mate this helps a lot, especially with the 2 board but real life scenario they being in separate rooms
My older card has it but my newer card doesn’t
