So you doing periodic as a safety check and issu satisfactory certificate cause it complies with 15th edition and it is safe while 17th edition released so far. Something goes wrong and the reason of that would be one of the reasons why they amended 15th edition up to 17th and will come back to you saying you said it is safe. So what excuse you will say? I made a note that it complies with 15th edition put my signature that it is safe and you let landlord to get away for 5 years without upgrading installation to current standard which is safe enough for nowadays. I think note is not good enough because people do not understand 15th or 17th ed they only want to get clean and satisfactory cert. All techs moving and they have to maintain and upgrade their electrics as we do maintain our cars etc. It's like I said probably better to write that installation in good order but needs bringing up to standard rather to issue satisfactory.
People that decide that an installation is unsatisfactory just because it doesn't comply to the 17th IMO are incorrect. Most times it is scaremongering to get some remidial works.
When you carry out an EICR we are assessing against the current standards of BS7671 as amended, and as long as there were no C1 or C2 i would say satisfactory and just list your recommendations and obs make the client aware of what is required to comply with the 17th with your C3
Yes but basically by giving satisfactory cert just to help people avoid remidials is not right, also you put your signature on it.
why would you leave C3 while to rectify C3's usually cost a tiny amount to the client and after 5 years have more than those C3's you left?
the whole point of an EICR is to " determine whether or not the installation is fit for continued use". would you take a car off the road just because it didn't have airbags and ABS?
I think it depends on what conditions you will have to drive. :) If it's snowy and you drive very fast I bet you would take it off the road :)
A 1901 Dion Boulton doesn't have seat belts fitted, yet if everything works correctly and is safe it will pass an MOT. The fitting of seat belts is not retrospective, same with the Regs.
Rewire and new CU only way out, then.
When was the last time you heard of a fuse not working?
I think you could find it could be quite costly to upgrade from old editions to current, at the end of the day we are engaged to provide an insight into the standard of the system not to provide a quick fix, that is up to the client
because firstly it is not our job to force people to have work done that they don't want doing, wether it is safe to leave as is or not. Secondly an EICR is a statement of current condition, so you would list all issues and the C1,2,3 coding directs the customer to the severity of those issues. ALL C1,2 issues would require an unsatisfactory result, a C3 would not, although carrying out the recommended work would improve the general safety of the installation. But at no point does the carrying out of an EICR demand that you or the customer carry out any work.
if you were to carry out a EICR and place only C3 codes against anything you found, then say it is unsatisfactory, you would be in the wrong and liable to some form of prosecution.
Right or wrong the ESC and the IET have deemed this to be the case, and in your OP the remedial work required to bring upto 17th from 16th would be fairly minimal to quite costly dependant on the installation requirements, say maybe 4 square D rcbo's at £50 a pop plus bonding perhaps.
and you do not sign to say " it is safe" you sign to say that you have tested the installation and made an assessment based on that inspection and testing procedure.
this thread seems like it could of been started by DC
Id actually doubt it would need an MOT, as there would be nothing on it to test
We are not forcing people to do any remidials cause EICR doesn't state that client must do any work as it is their money and they decide what to do with them as long as they know that this is wrong and you r not covering it with your signature. The other point is that we r not creating rules we just following them. Then you can basically buy cheaper stuff and do installation based on 15th edition and say EIC that they can not force you to buy more expensive materials to make installation safe like it is i.e. 17th ed because 15th edition is safe enough for continuous use.
I just wanna to know other people opinion and discuss about it cause to me it is a bit of a grey area where electricians have their own right to make a last decision when our signatures in use and we have to cover our asses.
Inspection & testing pass/fail
Thread Tags
LPM,
SirKit Breaker,
