E
edrobbo8
Had a builder call me on Friday, saying he has a bit of a problem. To cut a long story short, the spark who has done some work on this bungalow (upstairs converted to bedroom with semi enclosed bathroom) did not put an extractor in as apparently he was asked not to by home owner. LABC came round and said even though there is a Velux window in bathroom, it needs an extractor as well.
Owner doesn't want extractor to be turned on by light, wants it off seperate switch, LABC said this is fine. There is a socket outlet on wall with shower on the other side, and she wants the power to come from there, up the wall via FCU and to extractor so it can be turned on and off by the switch, alongside shower on/off switch. All works have been done, ceiling is plasterboard and decorating etc has all been finished (no entry to loft space either, centre of shower is about 500mm from exterior wall). Shower tray to roof height is 2.15m, I think it will need to be a SELV unit, and drill a hole from the outside to install ducting, but outside to get the ladders up to where you need to be it is a corrugated plastic carport.
It is going to be a right pain I think. Any other solutions anyone on here has?
