I have to install a shaver point in the breeze blocks of an outside cavity wall, so would use a 47mm plaster box. The problem is that the only practical location is about two feet below the end of a window lintel (and about 4 or 5 inches in from the edge of the window recess (so under the end of the lintel assuming a 6-inch lintel/wall overlap.
Is it permissable or sensible to remove 47mm of a breeze block in such a position?
Comments appreciated.
