installation certificate for bonding? | on ElectriciansForums
Discuss installation certificate for bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
morning gents
just a quick one...i was wondering if its correct to issue an installation cert when installing a main bond to an incoming service for the first time on an existing install.
if so would you just leave the circuit chart blank????
ta all
vitoboy
but is a minor works not just for modifying existing circuits.
this is a new bonding circuit that previously did not exist..
thats what made me think ...i installed it so...i do and installation cert???????
what do you think pc?
Bonding isn't a circuit tho'.
The act of issuing a certificate is to certify that you've carried out the work to regs. If all you've done is add bonding, then an MWC will perform this function fine. There'll still be plenty of na's on the form.
Keep it simple, for you and the client.
I asked my assessor this in the early days and he was fine with an MWC.
Reply to installation certificate for bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Do a minor works for connecting the new gas boiler and add some notes regarding the addition of the bonding.
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
