E
eagleeye
I have just tried to fill out my first cert for a new rewire. i know i should know this but am stuck and hope someone can help. The rewire was a TT system and i used a Legrand CCU with RCBO's for every circuit. right, the form....
Im registered with the NICEIC as a Domestic Installer just so you know what forms im on about
The electrode resistance, Ra. All i did was measure the earth fault loop impeadence which was14.5 ohms. what should this be ?
next the method of measurement for earth electrode ?
"the nature of supply parameters" part. external earth fault loop impedance Ze and the part "particulars of installation ath the orgin - measured Ze. are these the same or do i leave one blank ?
"characteristics of primary supply overcurrent protective device/s" - the BS(EN) number of main fuse. is this BS 88 ? and what type should it be ?
should maximum demand be about 40 amps ?
sorry there is quite a few things but i hope you can help
