Installing a 3-way switch | on ElectriciansForums
Discuss Installing a 3-way switch in the UK Electrical Forum area at ElectriciansForums.net
Jimbo54
Connecticut
I am trying to replace a 3-way switch that has 2 switches on it. Total is 3 sets of 2 switches each.
Switch I am removing has a red and black wire that go to 2 black screws on the right side. Off has both switches to the left.
On the left side there is a black wire connected to the bottom of 2 gold color
screws.
Lowes gave me a switch with 2 gold wires on the right. They is a green screw in the middle. 2 brass screws on the left that are connected. I put that other black wire on the lower screw.
Lights work fine now except the other double switch that is in the middle doesn't work now!
What am I doing wrong?
I put the red and black wire
Reply to Installing a 3-way switch in the UK Electrical Forum area at ElectriciansForums.net
Ah yes my apologies, thank you much appreciated.
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
