Installing a Fire Alarm System in a Restraunt | on ElectriciansForums
Discuss Installing a Fire Alarm System in a Restraunt in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
AshFR
Installing a fire alarm system in a restraunt soon and need a little bit of advice as we have never really installed a fire alarm system like this. Heres a quick list of what i think is needed. Ive done a fair bit of reading up also had a quick chat with fire officer about L2 system and all that so heres my outcome.
Ground Floor
Small Corridor at front entrance
Seating Area, Steps to second floor seating area
Bar with a few fridges, potato oven and hot food bar
Cellar (Steps going down)
Large Corridor leading to rear entrance and small dishwashing room
First Floor
Seating Area, Steps from ground floor seating aera
Kitchen
Corridor leading to steps down to large corridor on ground floor
2 Toilets (Male and Female)
Second Floor
Corridor leading to:
2 Bedrooms
Living room/office/small kitchen area (Microwave, Kettle, Toaster)
Bathroom
Utility Room with washing machine and tumble dryer
Ground floor - 1 smoke detector in seating area, 1 call point by rear entrance, 1 call point by front entrance, 1 sounder in seating area
First Floor - 1 smoke detector in seating area, 1 heat detector in kitchen, 1 call point and 1 smoke at top of stairs leading down to large corridor, 1 sounder in corridor
Second Floor - 1 smoke detector in each bedroom, living room and top of stairs (4 in total), 1 call point at top of stairs, 1 sounder in corridor
Is this enough equipment to cover the whole premises?
without seeing a plan and knowing the physical size of the establishment, it's hard to guess, but from your post, there may be a need for more sounders. you need 75dB sound level in each room ( esp. bedrooms)
Reply to Installing a Fire Alarm System in a Restraunt in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Heat & Carbon monoxide detector recommended for a kitchen.
