Installing an energy meter on a ring main | on ElectriciansForums
Guest viewing is limited
Discuss Installing an energy meter on a ring main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
uk
Hi guys, I have a client who wants to install meters on every power circuit in order to monitor energy consumption etc. Just wondering if there is a specific method to wire up such a configuration on ring mains? As far as I can tell, I'd need to come out of the RCBO to the meter, and then have the two legs of my ring main leaving the meter. Would that not then classify the circuits as radials?
Thank you!
They would become, in descriptive terms, a lollipop circuit. Use 4mm out to the meter if you’re keeping the 32A OCPD.
Just note it on the minor works cert
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Installing an energy meter on a ring main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
