Hi guys. I have been informed by uk power networks the following.
"As discussed on site as you do not require any extra power and you just want your 1p meter moved this will be a job for your supplier to install a riser to your flat and move the meter . I have attached a drawing that shows the current set up"
"It should be your electrician to install a cable and the supplier will put the red head and meter in your flat . ""
What cable would i use? Would i just work oht the ratings and put in a cable?. I have never done such a thing and need advice.
Cem
Cem
