Installing Earth Electrode Possible Gas/Water Pipes | on ElectriciansForums
Discuss Installing Earth Electrode Possible Gas/Water Pipes in the Australia area at ElectriciansForums.net
J
jimmycomeruk
I've been asked to install an earth electrode.
Do I need to check for pipes underneath where I propose to put the earth rod?
Do I need to perform a CAT scan? I'm not entirely sure what a CAT scan is but if anyone is familiar with it, all information and advice is welcomed.
CAT= Cable Avoidance Tool can also be used for locating services underground Iv used them on st lighting bit like the fuse finder Use=Experience and knowlage thay can give faulse results and should always be hand dug if suspissious
Did a CU change recently where there was an existing rod to be reused.....right in line with the service cable coming in:eek:.......it was only banged in 2/3 of the way,presumably the original installer bottled out of going all the way in.As we got a good reading we left well alone,mind you if it had just nicked the neutral we would have got a really good reading and could have called it PME.:p
Reply to Installing Earth Electrode Possible Gas/Water Pipes in the Australia area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
This is an RSS feed of thread: Gas or Water Pipe? Look to find cause of damp in wall. Content of the thread: Hi all, First time post so please...
