Installing external post lighting | on ElectriciansForums
Discuss Installing external post lighting in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
Hi all, just looking for ideas on how you typically install decorative garden lighting (say s/steel) - post type, into soft ground. Customers often provide B&Q type fittings with two/three base fixing holes which are a real pain. I previously had some great bases made up in plastic for a large job - diameter the same as the light base, with a centre rod which could be used to spike into the ground, as well as a threaded hole into which you could insert flexi conduit from the bottom. The light was just screwed onto the plastic base using s/s machine screws. Unfortunately, the company which made these up very cheaply is no longer around (maybe that's why!), but I'm now looking for time-saving tips for installing this type of lighting.Regards
Thanks Tel - I should have said that I'm trying to avoid that type of approach - often they need cutting down and if the lighting is going into beds it's not ideal. I've also tried the larger driveway blocks, but can't help thinking there must be a more efficient/elegant solution (if I can't get whet I used before made up at reasonable cost to suit individual jobs).
We normally drill a hole through a paving slab for cable entry (from Wicks), and then fix the post to it. The slab is then buried under the soil, gravel, lawn, etc, to provide a stable base for the light fitting. Sometimes if the fitting does not allow it, we put an IP rated enclosure under the slab for the SWA’s.
Reply to Installing external post lighting in the UK Electrical Forum area at ElectriciansForums.net
