A
arctic
I've been asked by a customer to install an outside socket just below the meter box. My question is if I where to split the existing tails in there meter box using henly blocks. Then install an IP rated 1 way RCD board in the meter box and take the socket from this would it break any regulation? Obviously everything would be securely fixed in the meter box and any holes sufficiently filled. Thanks for your help!
