Deleted member 106280
Hi all,
I just installed the Nest 3rd gen into my new house, which was a bit of a mess - everything was wired straight into the old Honeywell ST7100 without any sort of junction box. It’s a Y-plan system with a (very old) Glow Worm 35F boiler, a Honeywell V4073A1039 valve and a UnitFive pump.
First time I wired it - given that it was all a bit as-hoc, I just switched the wires around but must not have wired the pump properly, so the boiler started and went a little crazy! I’m now adamant it’s wired properly after buying and wiring my own junction box, but the thing seems to trip as soon as it’s turned on. Initially I changed the fuse at the spur and it turned on which worked but as soon as the pump kicked in (or could be the boiler) it shorted. Now even after changing the fuses the power doesn’t seem to kick in at all. The circuit breaker hasn’t tripped so could do with any advice on where to look for the fault and how to fix it!
Any help would be much appreciated!
Dave
Dave
