installing new socket (insulated stud wall) | on ElectriciansForums
Discuss installing new socket (insulated stud wall) in the Australia area at ElectriciansForums.net
hi evryone
wondered if someone could advise on the best way to install a new socket in to a exisitng insulated stud wall. the ring final is protected via 32A MCB and wired in 2.5mm t+e. my problem is that i am unable to clip the new wiring to the stud work as per ref method 102 . is this possible to acheive ? am i missing an easy solution?
many thanks
It is the position of the cable(s) in its containment or the fabric of the building that affects its installation method not how it is held there that is important in my opinion. So agree with your post #6 - hope that helps:)
Reply to installing new socket (insulated stud wall) in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
