Installing outdoor garden lighting | Page 2 | on ElectriciansForums
Discuss Installing outdoor garden lighting in the UK Electrical Forum area at ElectriciansForums.net
S. Wales
Hi all,
After some advise.
I have recently built a retaining wall with steps out of concrete blocks laid flat. Around 700mm tall
The wall will hold back around 500mm or so of ground, leaving a nice 180mm ish of wall above ground level.
My plan is to install lights ( brick lights I assume ) in the wall, trying to hide connections while also being able to maintain them if the lights were to break or cables to fault, and it all be waterproof?
I am hoping with a finished result of lights in both sides of the wall ,but, at different levels, and some lights for the steps .
What would be the best way to go about this ?
All suggestions welcome regard all aspects of the installation ( lights, cable to be used, waterproofing etc)
I will prove some pics ASAP
Thanks all
Reply to Installing outdoor garden lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just wanted a bit of advice in regards to a small installation of emergency lighting. I have a fairly long warehouse that needs some...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
