Installing Solar PV between CU and Meter? | on ElectriciansForums
Discuss Installing Solar PV between CU and Meter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
pv_in_boro
Hello,
I have a social housing customer who wants to install the PV between the incoming single meter and the tenants consumer unit.
Does anyone know if this is possible?
Cheers
Yes, but why would your customer deny the tenant the free electricity. They are being paid a FIT plus 50% export. Unless it's multiple tenants of course.
Thanks fezzie - that's right it's multiple tenants on a row of flats. No landlord supply, they want to connect the system into one of the flat meters instead of installing a landlord supply for the solar.
I'm just quoting some flats myself. The a/c will be fed into the meter feeding the communal areas and the tenants association will receive the FIT.
Reply to Installing Solar PV between CU and Meter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
