Hi all, I'm having a terrible time after having building work done. The electric cable to my new hob was quoted and agreed 10mm, it's a neff 10100w induction, 43 amps. The electrics were subbed by the builder. The junior electrician fitted a 6mm. Another electrician from the firm came to power up and refused saying the cable was too small. It's approx 5/6m to fuse board runs down a wall in plaster then enters small flex conduit under new tiled floor. Owner of electrical firm said the cable wasn't too small and it would be fine given it's installation method & applying diversity. Smelling a rat I had another sparky look at it and he said it's not big enough. I then had another sparky do a written report and he also said the cable is not adequate. The original installer maintains it's safe, I'm only using half of the hob under advice of 2nd spark. Today I rang ELECSA technical and based on what I told him he agrees it's not big enough besides the fact I was quoted for 10mm. I wondered what you guys thought as I've gained so much information reading posts on here.
