Installing supply for a Hot Tub | on ElectriciansForums
Discuss Installing supply for a Hot Tub in the DIY Electrical Advice area at ElectriciansForums.net
RyanPaul
Liverpool
So I'm doing wiring for a hot tub, I've designed a simple circuit [ElectriciansForums.net] Installing supply for a Hot Tub
is there anything any one would change or do differently?
Want other people's advice or opinions :) the hot tub is 32amps
To add I am going to have a 4x4 metal clad box next to the plastic CU's and feed the SWA into the CU an tail an earth from the SWA to the earth terminal in the CU.
would you use 2 core or 3 core and use the spare core as Earth?
As mentioned in your other thread exactly the same what is the cable length first?
Thread closed - RyanPaul you alredy have a thread running regarding this project, please do not open multiple threads on it.
Reply to Installing supply for a Hot Tub in the DIY Electrical Advice area at ElectriciansForums.net
Anyone plumb a DIY hot tub? I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with...
siricosm
If the socket is installed in a safe place that's fine - you can't influence what people will plug in in the future.
