Instrument costs | on ElectriciansForums
Discuss Instrument costs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
daiplayer
I have a metrel 61557. costing ÂŁ100 ish off ebay nowadays. Deos all the tests i need it to.
Mega's.....over ÂŁ600 ish.......
Whats the difference ?????
If the Metrel does all you want from it, the difference is ÂŁ500 ish in your pocket mate. There is no need to be envious the guy with a Megger because he's probably envious of you getting an MFT your happy with and saving ÂŁ500 in to the bargain.
Exactly. Is there any reason at all for the difference in prices. A mate got a megga. An he swears by it. But when i ask why.....he cant give me an answer.
Sent from my GT-S5830 using Tapatalk
its what you have and what your use to using More often than not its also what you have been supplied with hence what your familier using
megger 1552,1553 all the way for me I have used others but keep going back to megger as they are easy and intuetive to use and spare leads ect are redily available not special order ( except the silly plug in 13a plug 0
cut plug off.... 3 cocktail sticks.....sorted.
Reply to Instrument costs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
Mine (Martindale PD90) gets used fairly rarely. You only need one if there isn't a source of power to check the tester still works after...
