Instrument to find the true R S T. | on ElectriciansForums
Discuss Instrument to find the true R S T. in the Australia area at ElectriciansForums.net
F
fonager
I need an instrument to find the true R S T. Any of you have some suggestions.
Ah a phase rotation sequence tester ! Loads around, do you just need the phase sequence identified or do you need to worry about phase angle as well. If it's just the rotation then my fluke T140 will do that.
Reply to Instrument to find the true R S T. in the Australia area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
As seems to be the norm., these days, just whacking 'the odd clip in' will probably suffice. :rolleyes:
