Insulation above recessed modulars | on ElectriciansForums
Discuss Insulation above recessed modulars in the UK Electrical Forum area at ElectriciansForums.net
B
BillyH
The client wants to insulate the area above a suspended ceiling. Is it ok to run the insulation over the light fittings or would it be advisable to work round them?
Reply to Insulation above recessed modulars in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
