T
tamlin
Hi - apologies if this in the wrong area, but I am new here! :sick:
I'm completing a university project on terminal boards and I'm having trouble with the calculations. I need to calculate whether the air-gap I have is a sufficient arc barrier. Hopefully the picture below will help.
600V DC cables terminate horizontally along top and bottom. The slot along the middle is the gap I'm referring to (for scale, this gap is 10mm).
Any help or suggestions would be much appreciated as I'm getting desperate! Please note, it is the actual formula/calculations I need, not just a yes or no! :teeth_smile:
Thanks!!
Thanks!!
