Deleted member 112675
As it says really. When testing LE or NE resistance > 300M ohms but between L and N I was getting a reading of about 0.2M ohms. Could it be the BG cooker switch that has two neon lights that is the problem?
If it is, after shoving 500V dc through them, should I replace this erstwhile brand new cooker isolator even if no other issue shows itself on the grounds that something could have broken during said test?
